LaBVIEW Call Remote Veristand
I have a HIL machine, which obeys the typical NI's architecture , i.e. one destop connects one realtime controller with LAN.
The desktop has two LAN ports , one is connected with the realtime controller ,the other is connected into the Local NET in my company.
I want to remotely control the HIL's desktop from my personal computer to run Veristand Project, so as to avoid much operation of the machine.I checked the LaBVIEW HELP ,and succeeded calling native Veristand Project, see as below:
Then HELP document say that I can set the IP address, So I think it supports remote controls,Then I change the diagram to the following:
It does not work,within my expectation.the port 2041 is found by Windows resources Management Tool.
Then ,what shall I do ,to complete the remote control ? and how should I point to the project path(my PC's path or the HIL's desktop's path?)?
(2,409 Views)
Accepted by topic author alii001
Hi, it's not clear that it doesn't work, and it will show the error?
there is the case about remote target between Veristand and Labview, maybe its helpful~
http://forums.ni.com/t5/NI-VeriStand/UDP-server-on-remote-target-with-Veristand-and-Labview/td-p/224...
(2,364 Views)
