LVH "linx" with Xbee
I'm working on a project whereby i'm using 1 arduino to monitor phase voltages on one location of a building and another arduino to monitor the status of a standby generator as well as control it from another location of the building.  I was wondering, since Linx  allows labview to communicate with arduino uno via serial communication,  can I use  xbee modules to wirelessly transmit the data  to and from both arduinos & a PC at those ranges. Also would linx allow simultaneous communication with both arduino boards  and Labview (from the PC) at the same time?
(2,560 Views)
@kreiss12 wrote:
can I use  xbee modules to wirelessly transmit the data  to and from both arduinos & a PC at those ranges?
You question is best asked at the Arduino forum or XBee forum. That is a hardware question.
Why wouldn't it? Two boards two different serial ports.
(2,557 Views)
