08-27-2013 11:45 AM
Hey John,
Status update: After getting everything installed (took me longer than I care to admit to resize my VM's partition), my test machine is in the same state as yours. I'll post back as soon as I have a solution for you.
08-27-2013 02:42 PM - edited 08-27-2013 02:46 PM
Alright, got it!
As you may have guessed from the /lin and /lin64 folders all over the place, we install both the 32 and 64 bit versions of ISE. We do this becuase some Xilinx targets require one or the other. It looks like the INSTALL script doesn't work for CentOS, but does for RHEL. As it turns out, you're missing the following i686 dependencies that are required to run 32-bit compilations, which you're doing. I used yum to install the following:
glibc.i686
libstdc++.i686
libgcc.i686
libuuid.i686
glib2
libSM.i686
libXi.i686
libXrender.i686
libXrandr.i686
freetype.i686
fontconfig.i686
zlib.i686
A couple of these reported architecture errors, so I had to install/update their x64 counterparts first.
It may also be important to note that I had the EPEL repo enabled. I'm not sure if it's required for any of these or not. I got most of these from a bug report that was filed, but then closed because CentOS is not an "officially supported" (aka not tested) distro
08-27-2013 05:17 PM
Thank you for the deep dive to resolve this. Sorry to hear that CentOS isn't supported - it's my favorite and most used distro here at our firm. Given that CentOS 5.6 worked great for LVFPGA2012, I mistakenly assumed it would continue to do so for LVFPGA2013.
I'll attempt to install the additional bits you found to be required. Will post back with success or fail.
Not sure I understand the 32 vs. 64 bit compilation, but I'll leave that to some arcane Xilinx FPGA thing.
Best,
John
09-16-2013 05:24 AM
Any update? (Having same issue)
09-16-2013 09:17 AM
I can only say that the above was all I needed in addition to the NI provided installation media... if you're having any further troubles, I'd be glad to help out as I can.
10-08-2013 08:48 AM
today I installed the 6.3 CentOS DVD along with the compile worker software.
Apart from installing the additional packages with yum I didn't have to do anything else.
10-08-2013 05:59 PM
That's encouraging news. My FPGA system has been on the road, but it returns next week. We'll give this a go then and report back.
10-09-2013 04:31 PM
To continue this topic, I have also the problem with compile worker (Xilinx Tools 14.4 from Academic DVD's).
Mine still generates errors.
CentOS 6.3 + additional .i686 packages. Compilation from Windows 7 machine (Dev. computer) direct to compile worker.
The first error reported in workerLog.txt is "CodePage 852 not supported".
What's wrong with this code page?
10-09-2013 04:50 PM
Are you using a "Central European language that uses Latin script(such as Bosnian, Croatian, Czech, Hungarian, Polish, Romanian, Serbian or Slovak)"? - wikipedia
Curious if that could be part of the issue or not, figured I'd check since that's the first thing that came up in google.
10-09-2013 05:02 PM
