01-18-2015 02:56 AM
Hi,,
recently we visited one site where one server and three workstations running with lv2009 when I checked the backup I can see only executables so if I want to modifiy the existing workstations whats the best way or where can i find the source code of this
sandy
01-18-2015 03:22 AM
01-18-2015 03:25 AM
no the situation is different... the system supplier is not there now and the entire contract is finished as I dont have much idea on labview executables I posted this query.
01-18-2015 03:47 AM
01-18-2015 03:42 PM
01-18-2015 05:16 PM
Contact the contractor. I'm sure they would be happy to draw up a maintenence contract. Truthfully, that's probably the only way you would get access to the source code.
01-18-2015 06:06 PM
01-18-2015 07:07 PM
The OP claims to be a CLAD. Rather pathetic if this is indicative of what having a CLAD means.
Also check out his post from a year ago - same topic -http://forums.ni.com/t5/LabVIEW/executable/m-p/2969047
01-18-2015 10:17 PM
I don't remember any application builder questions on the CLAD.
Although, let's be fair. There are enough sample CLAD exams available that you should walk into the test knowing the answer to ~50% of the questions. That means you only need to get 40% of the remaining questions right. That's only twice what you'd expect from random guessing. I'd expect most people that work with LabVIEW could pass the CLAD if they wanted to.
01-19-2015 08:33 AM
It is not about "any application builder questions on the CLAD", but rather the lack of problem solving skills.
The same problem has been sitting unsolved for nearly a year. Why hire this guy?
