11-17-2014 06:09 AM
Good day,
i'm searching the download for LV2009 Windows vista 32 bit.
I must adapt such a project and wont want to upgrade right now.
thx
Solved! Go to Solution.
11-17-2014 08:11 AM
Search NI.com. Pick Downloads, and software to filter the list. Eventually you find
11-18-2014 02:18 AM
Thank You for Your answer, but the link You present is a patch, not LV2009 32bit itself.
11-18-2014 04:42 PM
The fact that it is not available from NI's site for download probably means ... NI does not want you to download it (without a license).
Have you tried contacting NI directly and seeing if you could get it?
11-18-2014 06:38 PM
If you have LV 2009 discs lying around, you could use them to install - provided, of course, that you have a valid license to use it with (which usually means any license that is newer than the version you are installing, provided there is still "room" on the license for another install).
11-18-2014 07:18 PM
I'm sorry, but when I searched for it, it did not say it was a patch in the results. The title says what is says. And it doesn't say it is a patch.
11-19-2014 02:07 AM
The FTP site has it and the others - ftp://ftp.ni.com/support/softlib/labview/labview_development_system/2009/
From the size of the files there, I'm assuming it's just LV itself and that if you want other drivers or modules, you would need to navigate that tree and find their downloads. Like the others said, you would need a valid license to activate it.
