LV15 Desktop Execution Trace Toolkit not installing
I just upgraded/installed LabVIEW 2015 Developer Suite, but the Desktop Execution Trace Toolkit (DETT) errored out and failed to install.
I tried installing the DETT after getting prompted by NI Update, but suffered the same error.
Any ideas?
(3,797 Views)
Did you check the readme for DETT to make sure you have all the requirements?
http://www.ni.com/pdf/manuals/375337a.html
...If you're installing from a Dev Suite, i expect that you probably do.
It might be worth trying a force reinstall on just the DETT if everything else from the Dev Suite installed succesfully. This link has info on that, but be sure to pay attention to the note about using this with a suite installer.
http://digital.ni.com/public.nsf/allkb/ADD22E807D5A12AD862579EC00760F79
Hope this helps!
https://www.linkedin.com/in/trentweaver
(3,753 Views)
Trent, thanks, but no dice.
This is just weird and annoying...
(3,740 Views)
I have exactly the same problem.
I looked into it a little bit and it is reporting that the install fails because of a missing LV2013 dependancy.
Looks to me like someone messed up the packaging on this one.
I have a failure on my windows 8 notebook machine which only has LV2014 and LV 2015 BUT it installed fine on my desktop win 7 machine which has every LV version from 2012.
I was kind of hoping it would just magically just work one day as I haven't made use of the toolkit yet but seeing your post I guess maybe it won't unless it gets raised.
So thankyou for posting I look forward to the answer . Smiley Happy
(3,719 Views)
I'll call NI support today to get this ironed out.
(3,700 Views)
Accepted by topic author Stranman
Per NI's suggestion, and not knowing what the underlying problem was...
Installing the downloaded toolkit worked for me.
http://www.ni.com/download/labview-desktop-execution-trace-toolkit-2015/5325/en/
Good luck.
- P
(3,647 Views)
Downloading directly from the site worked for me. I just had to, during installation, uncheck suport for L V2013 and LV2014. I left only support for LV2015 checked.
Scientia est potentia!
(3,339 Views)
