05-12-2010 07:36 AM
Hello, first of all I'm French so I apologize if there is mistakes.
I've got a problem with a case structure I made to initialize my Analyser (working with ESPI from Rhode & Schwarz).
The user of the software will have to choose between 3 antenna to measure 3 frequency bands, with different parameters (RBW, etc...)
So I beginned a program which is joined.
My problem is: when i run the program with "Highlight execution", or step by step, it works.
But when I run it normally, the structure's label doesn't change when I change the selected antenna in the list.
Hoping someone is able to give me the reason.
sincerely.
Solved! Go to Solution.
05-12-2010 08:05 AM
I just tried you vi and for me everything seems to work as it should. When i change the antenna in the control it updates the indicator and the case structure seems to work too.
Not totally sure if i unerstood your problem correctly so if you could describe it in more detail that would be good.
05-12-2010 08:09 AM
05-12-2010 08:11 AM
05-12-2010 08:17 AM
For me, when I change the antenna in the control it updates the indicator, but it doesn't update the case structure label (it stays on the antenna active when I did run the program).
But when I run it step by step, it works..
Here is a screenshot :
05-12-2010 08:23 AM
Do you mean seeing the block diagram showing which case is executing when you run your program?
That only happens if you have execution highlighting turned on.
05-12-2010 08:24 AM
05-12-2010 08:31 AM
Ok, it works. I just made a test with a local variable and saw everything is ok.
Sorry for wasting your time...
Thanks Ravens Fan. And muks, I think you are laughing at me, please don't, hard day for me 🙂
05-12-2010 08:36 AM
05-12-2010 11:16 AM
JDlabview wrote:....., I think you are laughing at me, please don't, hard day for me 🙂
Vous ne devriez pas avoir honte. Nous ne rions pas des etudiants de Labview. A une temps, nous etions tous etudiants.
