LV RunTime: "vi is broken or one of it's subVIS can't be located"
I made a deployment image in TST 2010 DE. I used the LV2011 disk to copy the LV RT images. In the config the RT engine was set to LV2010.
I wrote the test vi in LV2011. Then I added it to a lvlib and then loaded it in TST. This ran under the DE from TST and LV. Then I made the deployment.
The test vi was under version 2011 and it resided some custom controls, spreaded across different directories on the network drive.
Message 21 of 27
(427 Views)
When I use the "FP.winbounds" property in my vi the RT2010 reports a broken vi? When I remove this property it runs.
Message 22 of 27
(416 Views)
Forget my last reply. I can't write to winbounds at RT.
Message 23 of 27
(413 Views)
Can I use cvt with the RT engine? It's better I install the DE?
Message 24 of 27
(409 Views)
CVT is supported by the Full Development System. I am not sure if the functionality is extended to CVT. You'll have to check on it. But since you are extensively using LabVIEW, why dont u go ahead and install the DE?
Prashanth N
Message 25 of 27
(407 Views)
Tnx Pachi,
I think it's a good idea. 🙂
Message 26 of 27
(405 Views)
Glad I could be of help 😉
Prashanth N
Message 27 of 27
(403 Views)
