LV Project Documentation
Hello
Could someone guide me on how to go with Project documentation of LV software.Is there any tool available for auto generation/semi-auto??
There is a Documentation option in VI Property,whether that can be used,if so how??
TIA
(3,178 Views)
Here is the list of documentation that NI looks for during the CLD test.
Documentation
• Is the VI documented through File»VI Properties?
• Are the subVIs documented?
• Are wires documented with appropriate labels?
• Is the functionality documented?
    • Block diagram level
    • Main and nested structure level
• Do front panel controls and indicators have descriptive names?
• Do VIs have descriptive icons?
• Are constants documented?
• Do front panel controls have associated tip strips?
• Does the top-level VI have a non-default icon?
    • Do all subVIs have consistent icon design? consistent icon design?
For project level documentation, I have found the bookmark manager to be extremely helpful.  Both with adding easily found notes, and just managing the TODO of the project as a whole
https://decibel.ni.com/content/blogs/labview-news-english/2013/10/18/5-things-you-need-to-know-about...
Finally, as for "auto / semi-auto documentation" the key there is just good programming practies.
• Use names that make sense.  Both for subVIs and for controls and indicators.
• Keep like data together in clusters and use bundle by name / unbundle by name.
• Use proper data flow.
Hope that helps.
(3,155 Views)
I agree and kudo what bowenm said. Additionally, a member sabri.jatlaoui was working on some tools for some automated documentation here.
(3,132 Views)
LabVIEW also lets you place any file in the project (as far as I know) so I have had people send me projects that include a text file or pdf readme explaining, at a high level, the project and its components which I greatly appreciated.
(3,081 Views)
I think Bowen gave a good list of low level code documentation, in terms of general "big picture" application doc, I suggest you have a look at NIWeek session "How to eat the elephant" (I think you can also find a video of the session here), it discusses architecture and give good guideline on how to document the architecture.
Hoope this helps
Epictetus
Antoine Chalons
(3,059 Views)
