11-12-2008 07:33 AM
11-12-2008 08:23 AM
CORRECTION---
The installer does create an executable, but I can't find it, other than in the "Add/Remove programs" service. I can add it and remove it, but not run it!! The directory does not show in Windows Explorer, nor does it show in the Programs listing.
11-12-2008 08:42 AM
Hi earl,
I hope you are doing fine. Here is the link that tells you how to build an installer. Particularly pay attention to step 3 -5 to see if you have set up the correct settings for source file to include in installer. Hope this helps
11-12-2008 03:37 PM
Hi Eearl,
Did the advice you were given help?
I was wondering what OS your using and what path your trying to save too?
I would make sure your in admin mode.
Kind Regards,
James
11-13-2008 01:27 AM
Nisar F wrote:Hi earl,
And step 6 shows you how to build a shortcut.
Ton
