08-14-2015 08:47 AM
@Yamaeda wrote:
Could it be that Mass Compile doesn't touch VI's inside LLBs? Can you open the LLB ones and resave?
/Y
I tried just pulling them out of the LLB and linking them like regular VI's. Didn't help...
08-18-2015 10:57 AM
Hello cbudtz,
Calling this function in a subvi in a small setup does not reproduce the issue on my system. Does the issue reproduce if just this VI is a project? I would like to get a reproducing example if possible in order to see the behavior and better troubleshoot. Does the delay decrease if you remove other VIs from the project. I would like to see if the issue is resulting from the size of the project or just the presence of the dll call. Also, are you sourcing the user32.dll from the Windows system32 directory or a copy of the dll? Thanks!
08-24-2015 08:34 AM
Hi Wear,
You are right. It doesn't seem to be the problem afterall. For the moment it looks like it's mostly connected with the size of the VI (its about 2MB) - if I delete a small (random) fraction of it, it resolves the save time issue. For now I'm just going to stick with VL2014 as it's not really worth the effort for me. Thanks for your help!
Casper
08-24-2015 10:08 AM
@cbudtz wrote:
Hi Wear,
Casper
This makes me think that "mass recompile" is not extending to the llb. What you are doing is changing the VI a little so when it saves, it recompiles. Can you extract the VIs, mass compile them then save them back to the llb?
08-25-2015 03:52 AM
Yeah, I did that already. I also removed the LLB entirely from the project and rewrote the menu system using internal Labview functions. Didn't help.
09-02-2015 01:26 PM
Hello cbudtz,
I would really like to take a look at the project if that is possible. We can upload it to our ftp if it is too large for the forum. Let me know, thanks!
