LV 2010 and PCI-MIO-16XE-50
Hi, I'm trying to use a PCI-MIO-16XE-50 with LabView 2010. Would it be possible?
I insert the DAQ card but I cannot see it from Measurements and Automation explorer. NI-DAQmx 9.3 is installed.
Any suggestion is welcome, thanks!
(1,970 Views)
Accepted by topic author kurt4916
That card will work fine with LabVIEW 2010. I sounds like it just isn't inslalled. This may have to be done when updgrading to a newer version of LV.
When you do a hard reboot of the computer, look for the Found New Hardware wizard, and follow the instructions.Otherwise, try Add Hardware in Control Panel.
Richard
(1,965 Views)
Thanks!!
I should have believed more in the Win instalation wizard
(1,949 Views)
