07-07-2013 07:22 PM
I use LV8.61 and installed driver for PXI-4351, NI435X v252.
While I try to use sample vi came with v252 (Measure Thermocouple (with Accessory).vi), I get error for
missing LLB, vilib\DAQ\MISC.LLB\Get DAQ Device Information.vi
Indeed I can not see \LabVIEW8.6\vi.lib\DAQ folder. How I get this LLB and needed update?
07-07-2013 07:48 PM
07-07-2013 08:12 PM
Thanks for reply. However, Traditional NI-DAQ 7.4.4 is already installed.
The product came with driver v2.5.
07-07-2013 08:20 PM
07-08-2013 02:10 AM
Actually, there is no "DAQ" folder at all.
The os is XP sp3.
07-08-2013 02:12 AM
Let me correct myself, there is no "DAQ" folder under "vilib", but there is "DAQmx" folder.
07-08-2013 11:20 AM
Sorry for my misunderstanding. Traditional DAQ was not installed.
In my control pannel, installed software list, within NI software, it showed TDAQ744 installed.
However, it was not. I installed TDAQ744 and sample vi worked.
Thanks for help.
07-08-2013 11:33 AM
You should mark Dennis' message as the solution to your problem rather than your own thank you message. First you will need to unmark your message as the solution by going to the Options menu to the upper right of your message.
07-08-2013 08:23 PM
I can not fine "unmark" in upper right option tag list.
I reported to moderator that I like to unmark.
07-08-2013 10:02 PM
Your message. The one you marked as a solution highlighted in green. There is the options menu to the upper right of that. In the green bar.
