After re-wiring the ground to Pin 3 (in addition to Pin 6) and ensuring that the Termination option on the ncsetattribute block is checked, the timeout errors previously mentioned are still occuring. Adjusting the baud rates to the sensor-manufacturer's recommendations has made no difference either. The only thing that I can think of that may be causing the issues now is that perhaps the LIN signal wire (which was crimped) does not have a clean enough connection... is this a possibility? If not, I'm really out off ideas (unless something in my VI is incorrect). Any assistance would be greatly appreciated.
Thank you for your time,
Colin
