I have an issue trying to read some thermocouples.
If I use BenchLink Datalogger SW the reading are ok. but if I use LabView the readings are like 80ohms lower.
I have noticed that after using labview to read my thermocouples if I change Sw to Benchlink the first 1 or 2 readings are also low but then they get back to reading normal.
I'm using Labview drivers and VI functions to take the readings in labview (using the data vis provided to use with 34970A).
I think there is something in labview that is affecting the readings but don't knwo what can it be as I'm using the provided VIs.
Please hel as I'm clueless...
