05-25-2009 09:42 AM - edited 05-25-2009 09:47 AM
hello I am acquiring at a rate of 8000hz, 16bits. My LowFc = 0.01 and my high FC is 1500hz. still I am getting that error 20020. I tried playing around with the filter parameters however that isn't working.
why is the filter giving this error ?
labview 7.1
thanks very much
Solved! Go to Solution.
05-25-2009 10:15 AM
You need to specify the sampling rate when converting the I16 (sound) data to dynamic data. Use "Build Waveform", wire your data to Y and specify dt (=125us at a sampling rate of 8kHz).
Take care, when I open your VI in LV 8.5 it looks like you're acquiring data at 11.025 kHz and not at 8 kHz.
Hope this helps,
Daniel
05-25-2009 11:03 AM
05-25-2009 11:53 AM
how can i specify the sampling rate to the conversion?
thanks for your help
05-25-2009 12:11 PM
The rate that you have set to 11025 in the cluster wired to the SI/SO config is the sample rate.
Ps in the filter block set the init/cont boolean to true with a constant
05-25-2009 12:24 PM
05-25-2009 12:33 PM
Se picture. Now the rest is up to you
05-25-2009 12:48 PM
yeh!
thank you very much.
05-26-2009 03:51 AM
there is not error, but i can't hear anything. i don't know why, before adding this filter it is all right.
and can you tell me what's the diffrence between 'menu deroulant' and 'menu text'?
thanks.
05-26-2009 04:34 AM
Sorry I have not used the Labview sound system for while. I forgot the rate value is enum not a integer. You have to convert it to a number. see picture. You will find the small "case structure" in the SO config or the SI config VI just copy it and paste it in
