11-08-2013 08:25 AM
Key F4 to retry the last function / instruction similarly in MS-Office ?
11-08-2013 08:33 AM
11-08-2013 08:36 AM
Your question isn't very clear on what you are trying to achieve.
I'm assuming that you're talking about capturing a user pressing the F4 button in your LabVIEW application to retry the last action/command. I think this would be possible using an event structure to detect the F4 key being pressed and using this to prompt your application to do that action/command again.
The event structure can be set up as follows:
How you actually implement this will depend on the architecture of your application - you'll need to remember the last action that was performed (perhaps on a shift register).
If you're talking about in the LabVIEW development environment itself - I don't think this is possible. You could suggest it on the LabVIEW ideas exchange though!
