10-27-2016 11:37 AM
I was able to replicate the issue using this VI and measuring through an electronic load and multimeters for verification. The current will not exceed 105uA when the load is set to 200mA.
10-27-2016 11:48 AM
So this is your test VI, see snippet below for others. Could you draw en electrical diagram to show us your wiring, including the resistor, etc.?
10-27-2016 12:00 PM
Just a quick mockup of the test circuit I'm using.
10-27-2016 12:10 PM
I'm sorry that my comments were very general. I can't see the original code because I only have LV 2014 installed. I think you are in very good hands with Blokk though. 🙂
10-27-2016 01:07 PM - edited 10-27-2016 01:10 PM
@AnthonyMN wrote:Just a quick mockup of the test circuit I'm using.
That "electrical load" is a resistor, yes? What is the resistivity in Ohms?
Edit: another question: why do you set the compliance level to 1.05 Amp? Why not 1 Amp for example? Is there any specific reason?
10-27-2016 01:12 PM
It's a Kikusui PLZ303W set in CC mode to 200mA. I set the compliance to 1.05A as that is the max allowed for this model.
