KEITHLEY2636B DIODE SWEEP
Hello, I am new to labview. i got the example from the internet to sweep the voltage. I have fabricated Diode and i want to see IV characterization using labview in keithley 2636B source meter. i want to know why my code is not working properly. It is showing error code 5042 and an overlapped action and i am not able to sweep the voltage from -5 to +5. Can you please go through this code and tell me where i have gone wrong. i want to know whether that code works for 2636B
(2,942 Views)
May I have your original codes ?
(2,052 Views)
That's just the code that comes as an example to the Keithley 26xx LabVIEW driver.  You can find it here..
https://www.tek.com/source-measure-units/2635-software/keithley-series-2600-2600a-2600b-native-labvi...
If you need help modifying or getting it running then post your code and we'll give you a hand.
Craig
(2,042 Views)
