08-03-2005 08:26 AM
12-07-2008 08:56 AM
I see no one answered your question on this forum, but what did you find out regarding implementing the protocol in LabVIEW?
Todd
11-10-2009 10:22 AM
Necromancing a very old thread ...
I need any help/insight anyone can give me working with CAN, specific to J1708 protocol and good hardware choices. Thanks
11-10-2009 01:04 PM
Hi Paul,
I'm working from memory here, but J1587 is a protocol using J1708 as the physical layer and utilizes a RS485 @ 9600 baud.
Maybe you are looking for J1939, which is the protocol running on top CAN and is used frequently (sometimes in addition to J1587) on heavy trucks (engine, transmission, ABS, etc) that runs at 250 Kbps?
Todd
11-10-2009 04:38 PM
11-11-2009 06:36 AM
If it is J1939, I can set you up with some vis to send msgs and decode received msgs (i.e. send/receive msgs using priority/PF/PS/PGN/DA/SA)
Todd
12-08-2015 09:49 AM
I am trying to use a RS485 Serial Port to create a J1587 Frame using the J1708 as the physical layer. Having some difficulty creating a frame. Has anyone tried doing this or have some Information regarding this?
