09-21-2015 03:44 PM
Please look into allowing movement of the cursor after enabling shift register so one could traverse to the other side of the for/while loop to enable the other side of the associated incomming parameter line.
You could also automatically create the shift register, if enabled to do so.
Solved! Go to Solution.
09-21-2015 06:55 PM
Are you reporting a problem or asking for an idea to improve LabVIEW? I can't tell by your message. Either way, post more information.
09-22-2015 11:07 AM - edited 09-22-2015 11:10 AM
Your post makes no sense and does not sound like an idea for a new LabVIEW feature.
If you need programming help, please notify the moderator to move this thread to the regular LabVIEW forum. Then please provide significantly more detail, e.g. attach a VI that demonstrates the problem you are having.
09-22-2015 11:58 AM
After modifying a tunnel on a loop instruction to perform as a shift register, I find it impossible to move the cursor beyond the left or right edge of the screen, as my loop instruction takes up more than one screen worth of real estate . If I try to move the cursor by grapping the cursor bar at the bottom of the screen, I loose the shift register cursor shape.
In order to make this work, for example, I move the cursor up and outside my loop instruction, and left click on white space. After doing so, the shift register symbol appears on the other edge of the loop instruction. I then have to move the symbol near the tunnel of the parameter I was implementing the shift register on, and delete and move the lines to the shift register symbol. This is a nusance, however minor.
Therefore: One of three things has occured,
1) Either I do not know how to move the shift register cursor (cockpit problem) and there is a way to simpler do this? And if so, please let me know.
2) There is a bug in NI Labview
3) Or consider this is a request for NI to enhance (or fix) this issue.
Craig Byrd
09-22-2015 12:03 PM
Craig Byrd
What is a "loop instruction"? You are using LabVIEW. There is no such thing as "loop instruction".
What is "grapping"? How does one "grap" a cursor bar? I didn't know LabVIEW has a "cursor bar".
09-22-2015 12:06 PM - edited 09-22-2015 12:07 PM
Hi Byrd,
This is your real problem!
The style guide recommends to limit block diagrams to screen size. If you would follow the style guide you could create shift registers quite easily!
Think about subVIs and cleaning up/refactoring your code…
@nyc:
The OP converts a tunnel on the right side of a loop to a shift register. Then LabVIEW wants you to pick the corresponding tunnel on the left border of the loop - the OP has problems to locate that due to bad coding style…
09-22-2015 12:11 PM
OK, so this has to do with diagram editing. Who would have guessed? (I was imagining graph cursors, for example).
I understand now that you are trying to convert a tunnel to a shift register on one side of a loop and then link an existing tunnel on the other side to it, but that tunnel is out of view. You lose focus when trying to scroll.
I don't have a good solution for that, except keeping the diagram size more manageable. As we said in the LabVIEW proverbs: "If your LabVIEW problem can be solved by getting a bigger monitor, the problem is elsewhere". 😄
09-22-2015 12:25 PM
Thank you for your reply.
Yes, If the loop is displayed in the area of the screen, there is no issue.
And, yes, I could create more subroutine vi's to make the whole loop visible on the screen.
I would be concerned about readability of the source, as there are nested switch statements within the loop, but I will take this under advisement.
I still believe, however, NI should look at this and allow one to move the cursor beyond the display width of the monitor.
09-22-2015 12:32 PM
Thank you, appreciated..
I will endevour to follow recommend practices (maybe you could recommend the list or a link to same).
09-22-2015 12:45 PM
