08-22-2014 09:58 AM
I have a LabVIEW FPGA project whcih is designed in 8.6. When I open it in 2013 I see some of the wires in the target VIs are broken while I can open it with no issue in 8.6
Also when I try to compile the code I get 61055 internal error
Coudl you please let me knwo what shoudl I change to use 8.6 FPGA code in 2013
08-22-2014 10:22 AM
Fix the broken wires. I know a lot changed between 8.6 and 2009 in the FPGA world, so I know there was some rework I had to do. Just don't remember what it was.
08-22-2014 10:54 AM
I use VHDL code as componenet level IP. For exampel I see some of the FPGA IO Nodes are grayed out so the wires are broken. Has the format of XML files changed?
08-22-2014 12:10 PM
No, the IP nodes files will need to be updated. Go in to configure them and regenerate the code.
