Is there any way to replace instances of a global variable en masse while also setting up connector panes?
Accepted by topic author ijustlovemath
I ended up finding out that you can actually achieve the desired behavior, just do the following:
1. Open your global variable front panel:
2. Right click the one you want to replace with a new VI, and click "Find Global References":
3. Click "Replace With" and select your new VI.
Message 11 of 11
(786 Views)
