Is there an easy way to convert a "1d array of strings" to a "2d array of unsigned bytes (U8-8 bit integer)
Is there an easy way to convert a "1d array of strings" to a "2d array of unsigned bytes" (U8-8 bit integer).
Message 1 of 9
(3,651 Views)
Accepted by topic author chuck72352
Hi chuck72352,
this should work.
Mike
Message 2 of 9
(3,643 Views)
If your string array elements are set to "hex" display mode then you can just use the String to Byte Array function inside the loop.
Message 3 of 9
(3,637 Views)
Attached is the VI that I believe you showed me. Output exists in only the first column. Did I misread your vi?
Thank you.
Message 4 of 9
(3,627 Views)
I attached the wrong file  should be as attached.
Message 5 of 9
(3,624 Views)
Attached is the VI as I believe you showed me. Only the first column is being populated.
Message 6 of 9
(3,620 Views)
HI chuck72352,
as i wrote in the image. First change view to "code display" and then enter "\t" as seperator.
Mike
Message 7 of 9
(3,614 Views)
Sorry, but I don't know what you mean.
Message 8 of 9
(3,609 Views)
I figured it out. Thank you!
Message 9 of 9
(3,606 Views)
