07-02-2005 04:23 PM
I have built some applications for remote control using data socket technology. The remote control is made via web, using ActiveX technology. This technology is platform dependent. For this reason I want change this way of remote control with an independent platform technology, like java applets. Is there a possibility like this? Any kind of suggestions are welcomed. Thank you.
07-03-2005 09:44 PM
Couldn't you just use plain LabVIEW for the remote control application? It understands datasocket natively and runs on PC, MAC, and some other platforms.
Could you give a little bit more detail on what you are trying to do and how the remote control currently works?
07-04-2005 12:27 AM
I want to escape for Runtime Engine install. I don’t want that my client must install the LabVIEW Runtime Engine or anything else like this. In this moment, my client uses the web pages with ActiveX for remote control. The client must permit install the ActiveX in his PC and must to have a web browser that recognize the ActiveX technology. For this reason, I ask that there is a way to replace the ActiveX technology (which is platform dependent) with Java applet or with other technologies that are platform independent.
Thanks a lot.
07-04-2005 01:10 AM - edited 07-04-2005 01:10 AM
Message Edited by tst on 07-04-2005 09:15 AM
Message Edited by tst on 07-04-2005 09:18 AM
07-04-2005 01:50 AM
Thanks, I’ll try it. But this tool don’t use the data socket transfer protocol.
My question is: Is there a possibility to implement data socket transfer protocol in java applet or in other platform independent technology?
Any other suggestions are welcome.
07-04-2005 04:11 AM
Shhhh...
Don't tell anyone I told you this - LabVIEW IS platform indepedent!
Seriously though, you want to use DS (why, by the way? What's wrong with standard LV remote front panels?), but you don't want to install anything. I don't think you will find any java applet that implements DS internally. DS is an NI protocol, and I doubt they wrote an implementation for it in java. At most, I think you will find something that calls the LV exported functions.
In today's OS world, it is very hard to get something to work properly without installing it. You can get LV apps to run without installing the RTE, but I doubt you will be able to run a browser plugin, on any system, without installing\registering something.
Like Altenbach, I'm also not clear on what use you make of DS.
07-04-2005 07:45 AM - edited 07-04-2005 07:45 AM
Message Edited by rolfk on 07-04-2005 07:46 AM
