04-08-2016 10:24 PM
I have this issue, i need to recover the VI that I made, but the only file I have now is the .exe, lost my whole program in Labview, is this possible ??? ASP
04-08-2016 10:30 PM
Was it a debuggable executable? If so, you can see the block diagram. If not, I've got some bad news for you.
04-08-2016 10:43 PM
natasftw escribió:Was it a debuggable executable? If so, you can see the block diagram. If not, I've got some bad news for you.
If so ? What could I do ?
Thanks !
04-09-2016 02:05 AM
Thanks !
You have to program your VI again. You cannot revert an exe to a VI, unless you had debug mode on, see above...
