07-07-2015 12:13 PM
07-07-2015 12:22 PM
@tst wrote:
The DB toolkit can't read ANY file. It uses ADO or ODBC,....
Yes, Ok, but you know what I meant
tst wrote:
In the case of SQLite, you need to find and install a small free driver which provide ODBC support, which then allows you to access it through ODBC.
Ah ... I was hoping I didn't need to do that, but that's good to know. I'll try that, but the toolkit mentioned above may work out too. Thanks !
07-07-2015 12:24 PM
@Eric1977 wrote:
http://www.connectionstrings.com/
I have been there and have tried lots and lots of the examples, but no joy ... yet
07-07-2015 12:32 PM
07-07-2015 12:43 PM
So what have you tried ?
Did you install the ODBC drivers for SQLite ?
Did you try this string: DRIVER=SQLite3 ODBC Driver;Database=c:\mydb.db;LongNames=0;Timeout=1000;NoTXN=0;
SyncPragma=NORMAL;StepAPI=0;
What was the errors when you tried all these steps?
07-07-2015 12:57 PM
Sorry, bad SQL query ... fixed here...
07-07-2015 01:06 PM - edited 07-07-2015 01:10 PM
I can't at the moment, no admin privilege
It's at this link, right?
http://www.ch-werner.de/sqliteodbc/
No that's one of the millions of connection strings I haven't tried, not one of the hundreds I did try ... if I request admin privilege for my PC, I can try that. OTOH, I would like to find an option that doesn't require admin privilege on the customers' end.
07-07-2015 02:14 PM
If that's a requirement, then you're going to have to use the toolkits which call the DLL directly, as that's the only thing which doesn't require installation. That said, shouldn't you already have admin priviliges to install your application? Why can't the DB driver be part of that installation?
07-07-2015 03:12 PM
I was hoping to keep the installation simple by limiting it to just our one LabVIEW application. But "SQLite ODBC Driver" may be the only way for us to go, since I'm having issues with "SQLite for OpenG" handling some of our more complex queries. And even "SQLite Browser" on the target machine does not support "RIGHT JOIN", for example.
07-07-2015 05:19 PM
Yes, on the target machine -- which has admin privilege but not LabVIEW, so I make an application on the LabVIEW development machine (no admin priv) and copy it over.
Yes, and it worked ! I see the needle in the haystack now -- way at the bottom of https://www.connectionstrings.com/sqlite/ Thanks...
-john
