01-24-2014 08:10 AM
I have some coordination-data saved in a SQL file (*.db) by another program. The only thing I want to do is to read some values from these files without purchasing the complete database-toolkit. Is there a possibility in LabVIEW?
01-24-2014 08:22 AM
01-24-2014 11:02 AM
01-24-2014 11:49 AM
01-27-2014 08:08 AM
The Database Connectivity Toolset makes it easy to access a database by executing many of the SQL commands for you without requiring you to know SQL.
Maybe this helps
How to connect to MySql Database without using Database Connectivity Toolkit LV 2009
The Database Connectivity Toolset is the preferred method of database communication with LabVIEW.
As several of you are aware, the Database Connectivity Toolset comes with LabVIEW Developer Suite (list of included software can be found below) , with this package the toolkit must not be purchased separately.
07-07-2015 09:44 AM - edited 07-07-2015 09:44 AM
Well, I have the Database Connectivity Toolkit, and while I can read *.accdb and *.mdb files just fine, I am not able to read *.db files. The *.db files were created by another (non-LabVIEW) program running SQLite.
When I run the "Read DataBase Structure and Data.vi" in the LabVIEW examples I get this error:
NI_Database_API.lvlib: DB Tools Open Connec (Path).vi->Read DataBase Structure and Data.vi<ERR>ADO Error: 0x00000001
The file provided is not a data link (UDL) or a file DSN.
I am entering the file name as "connection information"; is this correct?
I am also in the process of trying this open source toolset:
https://lavag.org/topic/15613-sqlite-for-openg
... which makes it seem that the LabVIEW Database Connectivity Toolkit cannot be used to read a .db SQLite file ... or can it? The manual (http://www.ni.com/pdf/manuals/371525a.pdf) seems to be MS-Access-centric, with no mention of SQLite.
john
07-07-2015 09:50 AM
Is it possible to post your VI?
07-07-2015 09:56 AM
07-07-2015 11:56 AM
The DB toolkit can't read ANY file. It uses ADO or ODBC, which are components in Windows which are specifically designed so that your code doesn't need to know how to access the actual files, but will use a standard interface for accessing databases.
In the case of SQLite, you need to find and install a small free driver which provide ODBC support, which then allows you to access it through ODBC.
The toolkit linked to on LAVA (as well as the LVS one, I think) make direct call into the SQLite DLL, which does manipulate the file directly, so they don't need the ODBC driver. Of course, that also means that they can't be used to work with other DBs (unless code is added to support performing the same operations through ADO).
07-07-2015 12:12 PM - edited 07-07-2015 12:13 PM
Yes, but I'm looking for more specific info, namely help on a connection string, especially "Provider=...???..." (if needed). Obviously the string I have in the attached vi is wrong (for *.db files, though it works for my *.mdb and *.accdb files). I also attach a sample database from a SQLite demo and an image of what it looks like in "SQLite browser". Thanks !
