the first thing would be to get an image of the graph.
You can do this from a GetImage method node of the graph.
The next step would be to take that image and store it into a file somewhere.
Unfortunately the file storage isn't available in the base package (the write to jpeg or write to bmp file) so you'd need to convert the flattened pixmap by hand and work out either the xmp file format (fairly easy but no examples of this for labview) or converting it into a bitmap or jpeg etc.
Knowing where you stored it you could then print it say by useing something that
had an activeX interface so you could load the file, and send it to print - you'll have to browse around and find one probably, or use microsoft word.
The easiest option by far is to upgrade to a full or professional version where you'll be able to do the reports etc. quite easily through the nireports vis.
Sorry.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer
