12-04-2015 05:22 AM
Hello and good day.
I need to open an outlook compose window with pre-defined options (subject, cc, to: , etc..) did someone knows if is it possible? I had try some activex example but none of this is working on my pc.
Thank for the advice!
Francesco
Solved! Go to Solution.
12-04-2015 07:00 AM
Yup.
You can use System Exec on a Windows PC and use mailto: with tokens:
More info on mailto here: https://msdn.microsoft.com/en-us/library/aa767737(v=vs.85).aspx
(You can also use this technique to open webpages in the default browser. With great power comes great responsibility, however...)
12-04-2015 07:03 AM
Beautiful!!
Thank you very much "Spidy"....
