Is it possible to match multiple color patterns?
Is it possible to match multiple color patterns like the one shown in Match Multiple Geometric Patterns Example? I'm trying to create a VI similar to Match Multiple Geometric Patterns Example, but the only difference is I'm trying to learn multiple eye (iris) color templates then matching it to an eye.
Thank you!
Edited:
I'm trying to learn multiple templates then matching it to different image.
Message 1 of 8
(6,142 Views)
Please goto
Help>>Find Examples>>Search>>Color>>Color Classification example.
It has multiple color classification.
uday
Message 2 of 8
(6,127 Views)
Hello! I've tried that VI before. What I'm aiming to do is learning multiple (colored) image patterns then matching it to a different image.
Message 3 of 8
(6,124 Views)
You can create multiple template images with different Coloured Images and the do a pattern match and find which coloured Template is Matching with the Original Image.
Message 4 of 8
(6,090 Views)
@PalanivelT The output image when I'm using the Match Multiple Geometric Patterns is in black and white. How am I going to change it to RGB?
Message 5 of 8
(6,074 Views)
I don't understand why you are using Match Multiple Geometric Patterns for color matching, it doesn't work.
-If you post snippet(http://www.ni.com/tutorial/9330/en/) or vi it can help.
uday
Message 6 of 8
(6,059 Views)
Not much informative try to post code or VI Snippet.
Initially your question is on Matching colours but now you are mentioning back and White .
Share the code which you have tried and provide us your requirments clearly.
Message 7 of 8
(6,046 Views)
study this link it could help you could no use GM for color match
http://zone.ni.com/reference/en-XX/help/372916L-01/nivisionconcepts/color_classification/
Message 8 of 8
(5,983 Views)
