08-28-2014 11:42 AM
Thanks I will look at the example you mentioned
08-28-2014 02:52 PM
I like this array of cluster better, for the simple reason is that when I select a table cell the list appears and if I click another cell (before) I select a item from the list, the list will close and the program operation will not get out of sync with the cell I clicked on. I need to check out this example more to see how will it would work on a table to undetermined length.
08-28-2014 02:55 PM
Kaspar wrote:I like this array of cluster better, for the simple reason is that when I select a table cell the list appears and if I click another cell (before) I select a item from the list, the list will close and the program operation will not get out of sync with the cell I clicked on. I need to check out this example more to see how will it would work on a table to undetermined length.
ALso note that this idea would make these solution much more cleaner to implement. 😄
08-28-2014 02:57 PM
I never tried to extend that code to work with a list of unknown length so I can't help directly, but feel free to post (perhaps better in that thread) if you run into trouble and I'll see what I can do. It may be better to add your own vertical scrollbar control and manage scrolling yourself, rather than using the one included with the table control.
08-29-2014 06:55 AM
Implementing the functionality that I want/need may be a challenge, but also at the same time fun. My application is for a barcode read used in a lab. The user will scan items and the software will display information about the item in a table that contains numerous columns. One of the column needs to come from a drop down list and/or ring. The number of items in the list can go from 1 to 3000.
I need to be able to programatically detect if a list and/or ring is open and also be able to programtically close it.
08-29-2014 11:42 AM
I figured out how to make the code work the way I wanted. I updated the "Table:Mouse Down" event case to "Disable and Gray out" the Table Disable property node. This will require the use to select a item from the drop down before they try to modofy another cell in the table.
