09-28-2006 02:56 PM
09-29-2006 03:35 PM
Hello jpyung,
Thanks for contacting NI. What you can do is create two buffers outside of the while loop. One will be for the 12 bit grayscale images (I16), and the other for RGB. Create a case structure inside the while loop that will contain the same Grab VI in both cases. One will receive the buffer for grayscale, and the other will receive the buffer for RGB. The case structure will allow you to toggle between these cases and write images to each of these buffers respectively.
Mike T
