01-28-2016 01:28 AM
Hi all,
I am trying to download data with esimate size of ~100 MB with HTTP POST at one query.
For some reason I am getting error 363510, I am suspecting that it is related to the default buffer size of the HTTP POST function.
So, Is it possible to change HTTP POST Buffer size?
Are there any other reasons for getting this error code while using the HTTP POST? I've set the timeout to 2 minutes so this is not the cause.
Gil
01-28-2016 04:05 AM
There are a number of factors that can come into play here:
1) As the size of the data is quite large, it will take a fair amount of time to upload 100MB of data. On the client side, LV has a timeout and I think it will close the connection after 2 minutes.
2) The server probably has a timeout on POST data / script execution time.
3) Many servers have a limit set on the size of the POST data and/or any uploaded files sent to the server
As the amount of data is quite large, you might benefit from using a more reliable upload method or breaking the data down into small pieces before sending it. This reduces the risk of losing data in case you have a temporary connection glitch (it's pretty frustrating downloading a large file, only to have a connection problem at 95%!).
2 and 3, you need to check the settings on the server you are POSTing to. For 1, try uploading it from your computer to get an idea of how long it takes and set your timeout accordingly.
01-28-2016 05:24 AM
Hi Sam,
Thank you very much for your response!
The situation I described is only when downloading from the server (I am not uploading large amount of data).
The size gets big since I am downloading multiple rows of the same item (uploaded as small chunks of data- one row on each upload).
When downloading I have only one option and that's to get all the uploaded data for that item (all rows in the DB at once). And I can get it only in single operation (so without changing the DB management SW code, dividing to small units is impossible).
So I will check option 2,3. But if that fails or impossible to change or not the cause of the problem, is it possible that changing the HTTP Buffer in labVIEW size can solve the problem, is that even possible in LabVIEW?
Gil
01-28-2016 06:01 AM
It's not possible to change the buffer size but I do not know of any limitations in terms of size of data received. What is the error message that comes along with the error code?
You could consider implementing your own HTTP POST VI using the TCP VIs - open a connection on Port 80, send the initial HTTP line, some headers, a couple of line breaks, write your POST data and then use the TCP read function to keep reading until you have all of the data.
01-28-2016 06:45 AM
I am getting error:363510
Gil
01-28-2016 08:22 AM - edited 01-28-2016 08:23 AM
The error message sometimes includes a more descriptive message along with the general description for each error code.
01-28-2016 02:29 PM
The error message is:
Error 363510 occurred at LabVIEWHTTPClient.lvlib:POSTBuffer.vi:6120001
Possible reason(s):
LabVIEW: An error occurred while writing to the socket.
Any idea?
BTW increasing timeout from both sides (mine and the server side didn't help)
Thanks!
01-29-2016 10:58 AM
Hello Gilgil
I am wondering if you tried to use -1 in the timeout input just to see if that works.
Regards
11-25-2021 06:39 AM
I don't think it is buffer size issue yet, i am trying to send "&imei=353713115444367&sim_number=89462008006000106166" and i get same error and this in not big. maybe there has been an update of the encryption protocols on the server you try to upload to.
