Currently- Devices and IVI Driver sessions can only be managed within MAX on the development machine. So if you are assigning non-default Aliases for DAQmx or VISA or IVI session you are going to need to use MAX (The System API could also do this but depends on the MAX database and uses MAX itself as I understand it. It does require MAX to be installed )
On the Production machine you can restrict MAX accessability through user group policy to prevent muking and still permit technical staff some rights to view but not save. Clear so far?
DAQmx Channels, Tasks, Scales. can be:
- Created at run time
- Created and saved to MAX itself and used at runtime. They live in "xml hell" way over in NILand and DAQmx knows to go peek over there. Nothing prevents users with access rights from mukking around those files but, if anyone ever reverse engineers the format they can muk up everything so lock it down and don't mention it to users
- Created and saved in the LabVIEW Project (They acually live as lines of text in the xml file with the lvproj extension) and used at runtime in a built exe. IF you select the check box option to "Include My Computer Hardware Configuration" on the Advanced page of the exe build properties, a file called "NI-DAQmx.ini" is part of the build output and DAQmx knows to look in there first when called from that application. Nothing prevents a user with proper access to edit this file- don't give it to them or get tricky (I've seen some installs that simply overwrite this file on launch from a location known only to the developer, possibly even hard coded as a string constant within the app) The down side is MAX won't look there so tech staff can't test using the same Task, ch scales from MAX
"Should be" isn't "Is" -Jay
