03-28-2017 01:17 PM
This may sound like an obvious "Don't do that", but it was not easy to diagnose when it was accidentally implemented. If you make a Tab control page invisible and later programmatically switch to that page, it will become visible, but the controls on the page will not function correctly. No error is generated. Example attached.
03-28-2017 02:08 PM
I see the same behaviour with LabVIEW 2016.
Same with LV2015 SP1.
03-28-2017 02:18 PM
Good to know... Quite interesting - is it some kind of LabVIEW bug?
03-28-2017 02:34 PM
I don't think it is a bug, per se. Just a "don't do that" has the OP had set.
You may have changed to that page and it "showed" it, but technically you never made it visible.
03-28-2017 02:35 PM
03-28-2017 02:55 PM - edited 03-28-2017 03:10 PM
@JÞB wrote:
yeah, probably CAR 603092 install the f1 patch then let us know if it gets better.
the f2 patch is newly available too.
LabVIEW f1 patch did not solve the issue. I did not find f2 patch, only for LV x64. Is there f2 for 32 bit LV 2016 to try?
edit: found it: http://www.ni.com/download/labview-development-system-2016/6543/en/
Testing...
Edit2:
f2 patch, same result, same behaviour. Anyway, this is a kind of corner case. And another reason why using a SubPanel instead of a TAB control is just a better way to program...
03-28-2017 03:09 PM
Jeff,
Your link points to an NI Test stand patch. And I can't find that CAR# anywhere.
I have LV 16f2 installed. The behavior is just as originally described.
03-28-2017 03:11 PM
@RavensFan wrote:
Jeff,
You were faster than my Edit2 🙂
03-28-2017 03:15 PM
Here's the correct link to the CAR http://www.ni.com/product-documentation/53294/en/.
603092 |
After rearranging the tabs in a tab control, LabVIEW has the potential to crash when running or saving that VI. |
This isn't the same thing. LabVIEW doesn't crash. I've done some more testing and found the same behavior in LV2013
03-28-2017 09:50 PM
If this is only a programming error, I would expect LabVIEW to not open the tab and return an error. Making the tab visible, but not fully functional seems like a bug. In my example you can type directly into the numeric control and the value change is captured, but the increment/decrement buttons on the numeric control are non-functional.
