12-04-2014 08:57 PM
I am plotting a signal on Waveform Chart, and I have the Y-axis scale minimum of -5 and maximum of +5, but inverted. In other words, I have -5 above the 0 axis, and +5 below the 0 axis. I want to also invert whatever signal that is plotting on that waveform chart, such that positve amplitude of the signal is actually plotting below the 0-axis.
My question is how do I invert the plotting signal. Is there a specific function in LabView that I can use to invert the signal right before being plotted on the Waveform chart?
I would appreciate any suggestion.
Regards
12-05-2014 12:21 AM
Hi, Tebefia,
There is a checkbox of invert in the scale property of the waveform graph.
Does it relate to your question?
12-05-2014 01:12 AM
Hi Tebefia,
- you can invert the Y scale as you already did by setting the max value as range.start and min value as range.end…
- you can use the checkmark as already told
- you can use the simple, but effective Negate function
- you could swap the wires on your DAQ AI input…
12-05-2014 07:55 AM
William1225, thanks a lot for your response. I had that your suggestion done already as I stated in my posted question.
GerdW, thanks to you too and explicit answer. You did provide the answer to my question. Much appreciated.
12-05-2014 12:29 PM
You can show your appreciation by marking his answer as the solution. 😉
