Inverse Tangent Function Problems
I am trying to use the trigonometric function "inverse tangent", but it doesn't work as I think it should. I want to change a gradient into an angle, normally on a calculator I use height divided by length, and press the tan^-1 (inverse tan) function and get the angle. For example, the inverse tangent of 1 is 45 (degrees). If I use the inverse tangent function in Labview 2010, I get a completely different result = 0.7853.. Either I am using it incorrectly or the function isn't working properly.
I've attached an example so you can reproduce the result. I also had a similar problem with sin and cos in the formula node structures.
Thanks for any help you can give,
James
(5,263 Views)
Accepted by topic author MadScientist
Hi James
I haven't seen your VI. From what I know, output given by the trignometric functions in Labview is in radians. You will have to perform radian to degree conversion to get the answer as 45.
Regards
Javed
(5,262 Views)
Hi Javed,
I had no idea, thanks for the tip. I just had a look for radian to degree conversion and Labview doesn't seem to have one built in, but made my own and it works now. Thanks!
(5,257 Views)
You are welcome.
(5,250 Views)
LabVIEW has a VI (code drop) for converting radian to degree. Only I would never use it because it uses the expression node, which is not as efficient as normal LabVIEW code.
(5,248 Views)
Fair enough. I didn't manage to find their VI, but the conversion is a simple multiplication and division. radians*(180/pi) = degrees
(5,240 Views)
