11-25-2014 11:44 AM - edited 11-25-2014 11:47 AM
I two PXI-4351 temperature/voltage modules and cannot get the I/O assistant to recognize them under "Select and instrument". All I see is the two ports on my controller "COM1", "LPT1" (PXIe-8105), but not the 4351 instruments. When I open MAX, I know they are working because I get correct results on the test panels under the Traditional NI-DAQ tab. I also have the NI-435x 2.5.2 driver installed.
I don't know if this is related to the problem but when I am in MAX>Devices and Interfaces>NI PXIe-1062(my chassis)>6: NI 4351 for PXI, then I click on "NI-DAQ Configuration" then MAX crashes instantly.
Also, I'm running Wondows 7.
Can anyone help?
Thanks!
11-25-2014 12:22 PM
11-25-2014 01:50 PM
Thanks for the reply Denis,
What part is obsolete, the module? controller? Why would a working NI device be obsolete? I installed a device drivers update from feb-13. I have NI-435x 2.5.2, VISA 14.0.1, as well as Traditional DAQ 7.4.4. I am also running LabVIEW 2013
Is it possible to get this device working at all? How?
11-25-2014 01:59 PM - edited 11-25-2014 02:01 PM
Feb 2013 Device Drivers would not have support for LabVIEW 2013 at ALL find at leats the Aug 2013 DD DVD since that was when LabVIEW 2013 released.
And a "Working Device" becomes obsolete when the latest Device Drivers drops support for it and it can no longer be used in a modern system
11-25-2014 02:01 PM
11-25-2014 03:12 PM
Ok, I understand now.
Is the device still usable through programming with the palettes? or is there no chance of getting data from the modules from what you know?
11-25-2014 03:49 PM
Of course you can get data from it.
with a supported OS like Windows NT, a compatable Development enviornment like LabVIEW 7.1, and traditional DAQ. It would be a bear to maintain though. Much more cost effective to upgrade hardware!
