05-03-2013 06:51 AM
First and second picture shows the FPGA linked to an RT. Im trying to introduce a certain delay after "Head" is executed before Servo 1 is started. And delay again before Servo 2 started and continues to Servo 3,4,5,6, and Tail. It is a while loop until a control stop is pressed.
Question is, should the delay be put inside the FPGA or RT host?
I tried this in the picture below but failed
I need some idea on how to do it. Totally stuck right now...Thanks in advanced
05-03-2013 07:00 AM
How much of a delay do you want? It seems like what you really want to do is make your FPGA code more linear, not parallel.
05-03-2013 08:03 AM
it's best if the delay is connected to a control. The delay I wanted is 1ms.
its put that way because i need to control each individual servos
05-07-2013 02:49 AM
anyone got any ideas?
05-07-2013 03:20 AM - edited 05-07-2013 03:21 AM
Hi august,
your delay is located before the FPGA property node. The node will be executed after your delay: DATAFLOW RULES!
You should have one FPGA write node to set a new "head" value, then wait, then set the "servo" values...
05-07-2013 03:32 AM
05-07-2013 03:34 AM
05-07-2013 03:48 AM
so you're saying i should create another while loop with delay for controlling servo 1 parallel to the one controlling the head?
i prefer not to disturb the codes in fpga if possible
05-07-2013 03:51 AM
05-07-2013 07:30 AM
@augustg wrote:
so a total of 8 different fpga's?
No. 8 different FPGA Property nodes. You can then put in a Wait before each one to create the delay you want.
Or, as I was saying before, create a sequence in your FPGA with the delays you want before each write to an output.
