Internal warning 0x30EA5E5C & program's freezes
After each program launch I get an error "The last time you ran LabVIEW, internal warning 0x30EA5E5C occurred in fpinval.cpp.".
After this in my VI when I run it and try to stop it (by pressing "stop" button) right after this I get no effect. If I try to push some button inside VI (after pressing menu's "stop") then the program freezes.
So, I got several successful launches, and after that I've come to this. The same was after previous installation.
How can I fix it?
Log file is in attachment.
(3,277 Views)
Are you using any hardware with this VI?
(3,198 Views)
Yes,
1 USB-6211 via usb to control power supply and check result
2 stepping motors' controllers with CP210x chip for emulating com port (connected via usb)
1 adam-4561 with PL2303 chip for emulating com port  (connected via usb)
1 temperature controller via com-port
(3,179 Views)
I copied all contents of main vi to another vi, and this error disappeared. Looks like there were some problemes with this VI, it could be broken via pointers or something else.
Continue to investigate.
P.S. Suddenly error has returned, and this action doesn't help anymore. It seems that it's not so simple...
(3,150 Views)
Here is one of the error logs. I don't know how to read it.
Just remove ".txt" ending.
(3,134 Views)
The problem was with 4 custom numeric double controls. When I changed it back to default ones, the warning disappeared. I will check if this problem return.
(3,115 Views)
