03-08-2010 11:06 PM
I have two questions, first one : is there any limitation in number of elements to be placed on Block diagram of Lab VIEW FPGA VI, as while developing a VI with lot of high throughput fixed point adders and multipliers ( approximately 150 high throughput fixed point adders and 50 high throughput fixed point multipliers) Lab VIEW closing abruptly, anyhow I finished developing the VI by opening 4 or 5 times. After developing the VI when I try to save the file
Lab VIEW showing 'Not enough memory to complete this operation' error as shown in the figure, but file is saved.
Second One: After developing the VI I tried to compile the program to run on FPGA board here in intermediate stage only the same error as shown above occuring.I clicked ok thrice then the compilation stops and Code generation error occurs.
Details included are:
Error 100 occured at an unidentified location.
Possible reason(s):
LabVIEW: The VI is not in a state compatible with this operation.
Is this error occuring because of the huge VI?
My System Config:
Intel Core2Duo 3.16GHz
3.25Gb RAM
More than 100 GB free hard Disk space.
03-09-2010 12:33 AM
