01-13-2012 08:04 AM - edited 01-13-2012 08:06 AM
Hello
I want to let a subject get on the bike and as soon as they move the pedals, the dc generated voltage is displayed on a front panel gauge. Then I want to run a very short test/trial. I have an op amp circuit shaping the voltage from 0-12vdc generator output to 0 to -10 volts from my inverting amp to Labview.
I have a bike computer pickup/ magnet on the rear wheel. I just cut off the main computer. I juice up the pick up and every time the magnet passes, the voltage drops from 3 to 0Vdc.
See image of setup.
I want to run a timed trial (timed for say 3-5 minutes - it is hard to push against generator so short trial duration). When the timer is running I will utilise the magnetic pickup on the rear wheel to count revolutions. I want to keep the voltage output running to the gauge on the front panel. The table display with 6 lightbulbs represents 50W, 75W, 100W, 125W, 150W and 175 W respectively. The op amp circuit and table are bang on.
So I am doing this to create a user interface for the public who may visit our labs here at the university. Make it a little more meaningful to them.
Once I get the volts and revolutions displayed and input to the back panel, I can calculate distance in meters, calories per watt (based on subject data on front panel), watts out, joules, etc....
I want to try and redesign my program using the state machine architecture or maybe an event structure??
I was thinking my default state (I think state machine would work) could be volts generated by user and displayed on gauge. Then state 2 is has Start trial button been pushed (while continiuing to display volts generated the whole time).
This is not a complicated program, but I can get lost and make redundant code if I do this on my own.
I attached pics of my setup. I attached a pic of my front panel of the program I started.
I do not want to use it, just showing for reference.
My DAQ card is the Ni USB 6229.
Thanking anyone in advance.
NK
01-13-2012 08:11 AM
Sorry here is my front panel jpg
01-13-2012 08:32 AM
Please stick to your original post. This will let people know what has already been discussed. Thanks.
