Interesting Problem on a Graph
Sorry GerdW, I didn't get why did you include 8000 in the index sub array functions? What did you mean with that?
Add 273 on whatever Celcius said.
-Kelvin
Message 11 of 16
(795 Views)
Hi N.,
"limit the range of your data to interesting parts"
The other approach using a running mean/stdev is attached…
Message 12 of 16
(791 Views)
Okay, I will try and update you GerdW. Thanks for your help.
-Kelvin
Message 13 of 16
(787 Views)
Hi N.,
notice the edit I made to my last post…
Message 14 of 16
(784 Views)
Yes, yes I noticed it...  If I would change the amplitude scale of the graph you plotted in the second example that is starting 0 to 0.175 to my acualt values than I was done. Now I will try to adopt the second plot to the actual amplitude values in my original graph.
-Kelvin
Message 15 of 16
(778 Views)
Hi N.,
in the second VI you get just the peak position (X index), with this index you can read the Y values from your original data!
(Keep in mind the phase shift you get from the PtByPt function…)
Message 16 of 16
(777 Views)
