Intensity graph array troubles
I am trying to make an intensity plot of some x,y,z data. It is working, but I don't think it is working correctly. Could someone verify if I have the input arrays configured correctly? Thanks
S. LaCoursiere
(2,245 Views)
Hi S. LaCoursiere,
I don't know what you mean by 'working correctly'. However, I have attached a small image that shows how the Intensity Graph behaves when given a simple set of data. Notice how the Intensity Graph 'rotates' the values from the array 90 degrees counter-clockwise.
I hope this helps you.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,226 Views)
