Intensity-Graph Right-Click Menu and 'Mouse Up' Event
Does setting a 'mouse-up' event on an intensity graph disable the right-click menu?  Any way around this (ideally being able to effectively just set a left-button mouse up event which enables right-click menu)?
Don
(2,370 Views)
I can't reproduce this behavior (at least in 7.1). I get a mouse up event only with the left mouse button and the right-mouse button displays the menu. Check the VI Properties>Window Appearance and verify that allow run-time shortcut menus is checked. Can you post a vI that demonstrates the problem you are having?
(2,367 Views)
Yes, that was the problem.  At some point, 'allow run-time shortcut menus' had been unchecked.  Thanks for refreshing my memory.
Sincerely,
Don
(2,360 Views)
