Intensity Chart Probelm
Okey thanks it might be something wrong with my pc
Message 11 of 12
(449 Views)
Your use of an intensity chart makes no sense here. Your chart indicator never holds more than the last 128x50 values, everything else gets discarded immediately, so why are you creating these gigantic arrays? (your chart history size is 128 columns, the default for an intensity chart).
In my opinion you have absolutely no idea how an intensity chart should be used. What kind of data are you trying to display. Where is it coming from and in what form and what does it represent? What do you want to see during the run and in the end?
As a first step, try to understand the difference between a chart and a graph.
Message 12 of 12
(430 Views)
