Integration of an acceleration signal using a circular array is not giving the correct answer
I am trying to read an acceleration signal from a DAQ and then perfrom the time integration in order to obtain the speed and then displacement. I seem not to be able to perfrom the correct integration. i have been trying all the different types of integration blocks in labview. none of them seem to be giving the correct answer.
i have tried debugging the problem by feeding in a 1 HZ sinusoid from a voltage signal generator. although the integration did not show the cosine pattern and neither the correct amplitude.
i hope if someone has come accross this problem could offer some help. i feel down to earth not being able to perfrom even the simplest integration process.
please also check attached VI if that helps.
Message 1 of 12
(2,667 Views)
Hi Ali,
you may try this:
Message 2 of 12
(2,661 Views)
Many thanks, i will give it a go. would you be able to post the dot VI file please?
Regards
Message 3 of 12
(2,659 Views)
It's a snippet - and very easy to recode, so I didn't save it…
Message 4 of 12
(2,657 Views)
No worries, thank you so much
Message 5 of 12
(2,655 Views)
I have designed pretty much the same code as you have suggested, it sounds close, but unfortunately it didnt do it as expected. i am running with 4V peak to peak at 2 HZ using a sine wave as an acceleration signal.
Message 6 of 12
(2,649 Views)
Hi Ali,
please attach a VI with data embedded (by making all values default)!
Message 7 of 12
(2,630 Views)
HI GerdW,
thanks for your reply. I have attached the code.
instead of the Input AI0 input, you could just use a sine wave of 10 Hz with any amplitude as long as you know what the integration would so you can compare.
I really have tried all the possible integration blocks in labview, i have no idear why my integration is not working.
Kind Regars
Ali
Message 8 of 12
(2,624 Views)
Hi Ali,
what's wrong with the VI?
Everything as expected.
What else do you expect?
Message 9 of 12
(2,615 Views)
Hi Gerd,
Thanks for your patience. there absolutely is no problem with your code.
my problem is that i am reading continuously from a sensor and i want to perfrom the integral on the run continuously. unfortunately the way i am doing it according to the previous code that i have attached doesnt seem to do the integration properly. I tried to integrate a sine wave coming from an external generator with known attributes. unfortunately with the way the code is, it does perfrom the correct integration which should be a perfect cosine signal of same frequency. i believe this is happening to me due to the  way i am filling and empteying the buffer  as it is being reset to zero at every iteration of the outer loop.
i hope i will figure this integration problem soon.
Regards
Ali
Message 10 of 12
(2,586 Views)
