01-09-2013 12:38 PM
I am not trying to do anything too difficult here. I have a 30 Hz sine wave. 10,000 Hz sampling rate, 32500 points. I can see the waveform, no problem. I first pass it through the scaled EU vi. When I put it through the integration express vi I get the dt<=0 error. There isn't anywhere to tell it the dt, other than the incoming time waveform, which appears to be fine. What am I missing?
01-09-2013 12:52 PM
Here is the code that is giving me the problem. I have also included the time waveform I am feeding the eu and a_v_d vi's.
01-11-2013 10:36 AM
Hello rwbrook,
I tried simulating your process but could not replicate the error. Would you mind posting a screenshot of the error message?
Thanks!
01-11-2013 12:09 PM
thanks for the feedback. I was able to get it working! Now, the only problem I have is calculating the RMS overall from the integrated time waveform. With 32500 points, the ringing is settled out after approx. 1 second. That leaves 2.25 seconds of unadulterated time data to work with. What I need to do is cut off the first 1 second of time data. I will also chop the 32500 points of the tach signal as well so that the phase will work. I have found a vi for zeroing out data at the end of the time block, but not the beginning. Any ideas for getting that accomplished?
01-14-2013 01:36 PM
Hi rwbrook,
If you need to work with only a portion of a dynamic data signal, you may want to use the Extract Portion of Signal Express VI.
01-14-2013 01:36 PM
Hi rwbrook,
01-14-2013 02:10 PM
Josh,
Thanks! That sounds like it will work. As soon as my IT department fixes my laptop, I'll give it a try.
Ron
