06-07-2012 02:16 PM
I’m trying to set up the TortoiseSVN Diff tool, as described:
https://decibel.ni.com/content/docs/DOC-12175 and
http://digital.ni.com/public.nsf/allkb/3BEC521972301FF2862576EA00609CA6
To configure TortoiseSVN to use LabVIEW’s compare tool I added the following for “.vi” file extensions:
"C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe" %mine %base -nobdcosm –nobdpos
The links above tell you use “Program Files,” but on my system the LVCompare.exe is located in my “Program Files (x86)” directory.
When I try to run the diff tool (right click on the file in question -> TortoiseSVN -> Diff with previous version), I get the following error:
I cannot get the LVCompare tool to work with the command prompt either, as described:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/configlvcomp_thirdparty/
I did notice that it mentions the Compare tool is only available with LabVIEW Professional Development System. Does this apply for using it with TortoiseSVN as well? I am running LabVIEW 2011 Full Development System on Windows 7 (64 bit). The version of TortoiseSVN I am using is: TortoiseSVN 1.7.6, Build 22632 - 64 Bit , 2012/03/08 18:29:39 Subversion 1.7.4.
Any help getting the LVCompare tool integrated with TortoiseSVN to work would be greatly appreciated!
Thanks!
Lauren
06-07-2012 03:42 PM
What bit version of LabVIEW do you have ? 32 bit right ?
I think that this is the problem. Have you tried to install the 32 bit version of TortoiseSVN ?
06-07-2012 03:58 PM
I'm using SVN to manage my source. I will say that the LVCompare feels fairly buggy sometimes. In addition i'm using 32 bit however, for my .vi instances this is what my flags look like
"C:\Program Files\National Instruments\Shared\LabVIEW Compare\LVCompare.exe %base %mine"
I do not have the extra two flags which i believe just avoid comparing item position. I doubt this is your problem, but just some FYI. G/L
06-07-2012 05:08 PM - edited 06-07-2012 05:11 PM
dkfire,
Yes, I am using 32-bit LabVIEW. I tried the TortoiseSVN installer for the 32 bit version. It does an initial check (before the installer really starts) and gives an error saying you should install 64 bit.
Jed394,
The extra tags are:
I tried it without those and got the same error.
Lauren
06-08-2012 12:13 AM
Yes it does. LVCompare is only a simple wrapper executable that eventually tries to run a VI in the LabVIEW installation directory. And this VI will not work if the LabVIEW installation is not licensed as Professional Development system.
Note to the AEs: In the second link of Laura's post, it states incorrectly: Primary Software: LabVIEW Development Systems>>LabVIEW Base Package
This is completely contradictory to the note in the last link, that states that the Professional Development System is required. A documentation correction request seems in order.
